Hi guys,
I got this copier second hand with the HDD removed. I put in a new HDD and formatted it successfully, after the machine restarts it gets stuck ( I left it for an hour) on the screen attached below. I did some research and did the firmware with overwrite and got the same result, as the machine starts again after copying the files it gets stuck on this screen.
Is there a data erase kit that could have been removed that is causing this problem?
