Canon IRA C7260 Stuck on screen
  • Taggerung08
    • Sep 2014
    • 60
    Hi guys,
    I got this copier second hand with the HDD removed. I put in a new HDD and formatted it successfully, after the machine restarts it gets stuck ( I left it for an hour) on the screen attached below. I did some research and did the firmware with overwrite and got the same result, as the machine starts again after copying the files it gets stuck on this screen.
    Is there a data erase kit that could have been removed that is causing this problem?
  • lilleputte
    • Jan 2013
    • 154
    Re: Canon IRA C7260 Stuck on screen
    Hi. Try this
    COPIER > OPTION > LCNS-TR
    Put ST-HDCR2 TO "0"
    I know it may take time for the machine to boot, but 1 hour sounds strange
    • Taggerung08
      • Sep 2014
      • 60
      Originally posted by lilleputte
      Hi. Try this
      Put ST-HDCR2 TO "0"
      I can't get into service mode. I would try it though.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Did you try with Boot System Error Diagnosis Tool or Controller System Error Diagnosis Tool?
        • Taggerung08
          • Sep 2014
          • 60
          This was the closest answer. I tried to get it to do the Boot System Error and the Controller System Diagnosis thingy, neither of which worked.
          On a hunch, I replaced the Main Controller #2 and was able to finish updating the firmware, and get past that stuck screen, but to add another issue,
          I now have a brand new error code!
          E260-0002
          Any suggestions?
          • zoraldinho
            • Mar 2008
            • 5007
            I believe you forgot connect something.There is no 24V power supply somewhere.
            • Taggerung08
              • Sep 2014
              • 60
              There's 2 of them mate
              • zoraldinho
                • Mar 2008
                • 5007
                [ATTACH=CONFIG]37875[/ATTACH]
                [ATTACH=CONFIG]37876[/ATTACH]
                Yes, in the manual.. But did you check them if they all plugged in! E260 is related with 12-24V supply.
