Canon IR 1023 adf problem
  • office machines
    • Aug 2006
    • 33
    the adf feeds a blank sheet thru at different times, if I put in 10 pages I get 10 pages, some of which are blank. I replaced the adf unit, checked settings. any help would be great.
    thanks in advance
  • roho
    • Mar 2009
    • 844
    Re: Canon IR 1023 adf problem
    thanks in advance
    If I am to understand, there is no double feeding or jams from the adf, but there is blank pages? The CIS unit has been a issue on some of the earlier versions of this model.
    • office machines
      • Aug 2006
      • 33
      there are no jams, no double feeds. If I put 20 pages in the adf I get 20 pages in the output tray.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4524
        Did machine ever produce a blank page when just one page is fed through ADF? What about single pages off the glass?
        • office machines
          • Aug 2006
          • 33
          no if you single thru adf prints fine,
          use the glass no problem,
          print to it no problem.
          Only when you multiply copy thru adf do you get a blank intermittent page.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 4999
            Smells like bad adf paper sensor and occasionally scans from glass.Put something on the glass during adf copying to check.
            Inspect adf connectors,ribbon cable,adf pcb......
            • hidius
              • Jun 2015
              • 128
              this issue is caused by a sticky solenoid .. ive had lots of this model in the field with this problem and all resolved by replacing the solenoid
