Customer has an ir3245 that has the modification kit installed on the feeder as well as a new sep pad. Recently it started jamming if you put more than 1 sheet in the feeder. The second sheet will start to feed then jam. The jam codes are 0073 and 0046. I have a parts manual but don't have a service manual for this, can someone point me in the right direction.
3245 DF jam
Re: 3245 DF jam
HOLDER SEPARATION PAD UNIT===FL3-5538-000
The material of the separation pad for the Separation Pad Unit Holder in the Separation Reverse Guide
has been changed to a new type.
Jam Codes (ADF)
0073 = Release motor HP sensor = SR11------------Release NG------The Release motor HP sensor has not turned on
within the specified time (1 second).
0046 = Read sensor = SR2---------First read sensor stationary---A read sensor stationary jam has occurred
during feed of the first document
The location of SR2 is to the left of the platen roller.
Lift the Document Feeder and picture on the left below shows the platen roller.
Push in on the platen roller and S2 is in the middle of the feeder behind mylars.
check or replace DADF paper pick-up cover assembly---FM3-6891-000
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: 3245 DF jam
[ATTACH=CONFIG]37943[/ATTACH]
Jam Codes (ADF)
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
