iR3100cn Error code
  • Peter Sim
    • Sep 2008
    • 445
    iR3100cn Error code
    Hai, all
    what problem with this error code E020-03a2?
  • smiley
    • Aug 2008
    • 616
    one of your developer is no good.i dont know what color.
    there is no glory without sacrifice
    • 555
      • Jun 2008
      • 45
      03a2 sub code points to the cyan dev., poblem with atr sensor.may be dirty sensor ,or bad sensor, or stuck shutter, patch sensor above drum may be dirty(located at about 11 0 clock above drum)or drum could be weak check drum life if more than 80 percent then change drum.
      • 555
        • Jun 2008
        • 45
        oh, or weak carrier in cyan dev.
        • Peter Sim
          • Sep 2008
          • 445
          Thank you very much to all of reply.Is weak cyan dev.Change new cyan dev.solve the problem.
