Ir adv 6055 with 0112 jam code
  • T911
    • Jun 2007
    • 628
    The fuser was replaced and ps35 inner delivery sensor, worked for a little while but now i can't get 2 copies out of the machine. The one sheet goes through the fuser and stops at ps35 while the one right behind it hits the fuser rollers and rolls over in half and doesn't make it through the nip of the rollers. Ideas appreciated. This is the original problem. Machine has 1.7m thanks
  • Etech50
    • Oct 2017
    • 28
    Re: Ir adv 6055 with 0112 jam code
    The spring for the sensor flag at ps35 has been a mod to FC8-9450-010 due to 0112 and 0212 codes. The shaft just before ps35 has a one way gear that should be checked.
    • T911
      • Jun 2007
      • 628
      Great thanks and ill look into the shaft and one way
