I got another pesky 020 code, which I quickly resolved by replacing the Magenta developer, as the spatter shield was disintegrating and a piece got pulled into the developer unit. It happened to make a void on the developer roller exactly where the ATR sensor is, which I assume is why it pulled the code. It was my fastest 020 resolution of all time!
But, now I am experiencing some magenta registration issues. It varies from sheet to sheet. Some sheets are in perfect registration for all 4 colors, and about 1 in 4 have various degrees of mis-registrations for magenta only. It only varies by small fraction, but for 8-10 point type on business cards, it is too much.
I did have an 070-0201 error code on startup, where there was too much time in the detection of the home position and the next home position of the ITB. I cleaned the back side of the transfer belt in case there was toner buildup on the patch, and the 070 code has not come up again - but the magenta still has this varying registration problem.
Does anyone have any thoughts on this? This just started - prior to this it was in perfect registration every sheet. Not sure if it would be a developer issue or more related to the ITB.
