Windows 10 Home scan to file not working
  • RHodg57
    • Dec 2013
    • 191
    Customer upgraded to a laptop with Windows 10 Home. Now they can't scan to file. Their Windows 7 computer worked
    just fine. The copier is an IRADVC5035. I have seen some threads here but not for a Canon. I checked all the permissions
    for the folder and it's set the same way I have set others. I have set up scanning for other Windows 10 computers without
    problems. Just not the Home version. I can't browse to the computer. I get the send error #801 so I went through the
    items it listed and no change. Any ideas?
    Re: Windows 10 Home scan to file not working
    it's more of a Win10 problem... check out the threads in " Connectivity "
    • Guest
      Hi
      Check in windows 10 in Control Panel\Network and Internet\Network and Sharing Center\Advanced sharing settings password protected sharing turn off. password protected sharing off and will work.
        • 8131
        There is a firmware fix for this issue, its allows SMB V2/3 scanning.
        • RHodg57
          • Dec 2013
          • 191
          Do you know which version? I will update it with what I have.
            • 8131
            Its a special realease not available on CDS
            • tonerjockey
              • Apr 2014
              • 567
              this is what i did to resolve the issue with a update to windows 10 that suddenly wouldn't allow the connection to the scanner. i tried everything and couldn't do it. the customers young IT did it and furnished me with the procedure which i tried on another customer that had the same problem after an update. and it worked
              Go to services, locate Windows Image Acquisition service, select properties, go to log on tab, change to Local System Account, and check Allow service to interact with desktop.
              good luck, Jim
              • RHodg57
                • Dec 2013
                • 191
                good luck, Jim
                And this solved not being able to scan to file?
                • tonerjockey
                  • Apr 2014
                  • 567
                  well, it did for me with this particular issue.
