iR-C2880 progress bar hang
  • aAandy
    • Apr 2012
    • 370
    Hello people
    merry christmas one & all
    client moved this machine, powered it upon arrival, machine fires up, runs through checks, screen lights up and progress bar appears then hangs at about 2% in - the machine itself seems to come ready, because when i lift the ADF the exposure lamp lights and when i place paper in the ADF it does it's prep thing
    pulled the HDD, mounted it in my confuser, ran Hitachi Drive Fitness Test all OK - ran chkdsk on it (no switches) and it showed a bundle of errors, so i presume the machine was shut-down improperly.
    Should i run chkdsk /f and let it repair the drive? perhaps the bootrom or RAM are stuffing things up?
    any pointers very much appreciated
    thanks in advance
    Andy
  • copier tech
    • 8195
    Re: iR-C2880 progress bar hang
    The best option would be to re-write the SSW to the drive, i'd start there.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5016
      Viewed multiple times.Reseat all connectors,memory boards (ram,dimm).........
      • kuby
        • Oct 2007
        • 1410
        1. Also try running scan disk with in the copier, not from a computer.
        2. You might try reformatting and reloading the drive first.
        3. Hard drive going bad and needs to be replaced.
        • tech28
          • Jun 2013
          • 434
          Like mentions before, remove boards ans clean with alcohol, dry well, and reseat them. Had purchased 20 of these machines, several of them had similar problem, googled and there is a Canon Bulletin on this. 75% of them worked, resold many of them and no issues. That was last year. Good Luck. And Merry Christmas,
          • guitar9199
            • Sep 2016
            • 1100
            Reseat all connectors and System RAM....Reinstall system software using SST (Overwrite All). If it hangs up again, replace the HDD. Make sure the drive is the right one for the C2880 machines... Canon only allows certain model drives to be used.
            • aAandy
              • Apr 2012
              • 370
              i knew someone was going to say reload the firmware - anyone got it? i've got SST & manuals, but no firmware
              will also re-seat everything
              thanks for the pointers everywon
              • aAandy
                • Apr 2012
                • 370
                scan disk in the copier? is that hold down 1 & 9 at power up?
                • kuby
                  • Oct 2007
                  • 1410
                  Yes hold down 1&9 and turn the machine ON. Wait until the cursor is at the top left and the little boxes start to fall. Just let it run.
                  • copier tech
                    • 8195
                    As above but if you have physically removed the copier HDD & fitted it to a Windows machine this may have deleted the system files.
                    • aAandy
                      • Apr 2012
                      • 370
                      ooops, forgot to update this thread
                      problem solved by re-seating everything, HDD required nothing
                      thank you all for your assistance
