Canon 5045 SRAM
  • Lasersupplies
    • Jul 2011
    • 221
    Canon 5045 SRAM
    Hi I am looking some help. I have a Canon E355-001 error and I am trying to locate what is causing it. I have located the counter pcb which looks secure the main contoller pcb looks fine and the ECO ID PCB connectors are secure I am struggling to locate the SRAM would someone be able to point this out for me? thanks.
  • dan7777
    • Dec 2012
    • 680
    Re: Canon 5045 SRAM
    SM shows it on main controller PCB2. lt did not say exactly where I could see. Have you tried reloading software?
    • copier tech
      • 8172
      Re: Canon 5045 SRAM
      Theres a specific clear mode in special service mode to rest this error.
      This error isually appears after someone tries to wipe the main counter.........
      • teckat
        • 16083
        Re: Canon 5045 SRAM
        2016
        All imageRUNNER ADVANCE Series / All imagePRESS Series / All imageRUNNER Series
        E350 / E355 / E748 Error Codes
        Counter PCBs and SATA Flash PCBs are no longer available for purchase. As a result, please handle E350 / E355 and E748 in the following manner:
        E350 / E355 Error Codes:
        Call the Technical Support Center (1-800-528-2830).
        E748 Error Codes:
        Refer to the Service Manual. If the Service Manual states, Contact to the Sales Companies, stop and call the Technical Support Center (1-800-528-2830).
        *NOTE 1: For any of these error codes, do not swap any PCB's from any other machine. Doing so may render both machines unrecoverable.
        *NOTE 2: Do not use any of the User Mode or Service Mode clears when encountering these error codes. :
        (Executing the Service Mode or User Mode clears may render the machine unrecoverable.
