Canon ir 4580i
  • Service@PRT
    • Oct 2016
    • 181
    Canon ir 4580i
    Change, ibt cleaning blade, ibt, drum unit. Still the same problem.. do i need to configure it on service mode?
    Sent from my HUAWEI VNS-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • copier tech
    • 8202
    Re: Canon ir 4580i
    No you don't need to do anything in service mode after replacing the drum unit or the ITB cleaning blade (only a counter to reset but this wont effect the performance)
    Look like the quality issue only happens on magenta?
    • Service@PRT
      • Oct 2016
      • 181
      Re: Canon ir 4580i
      Yes only magenta. And not only copy even print one.
      • jitenderrawat1
        • Sep 2017
        • 5
        Re: Canon ir 4580i
        Its just only cleaning issue in magenta drum unit you only need to be clean cleaning assembly of magenta. Drum unit
        Sent from my CPH1701 using Tapatalk
        • copier tech
          • 8202
          Re: Canon ir 4580i
          So you replaced the magenta drum?
          Are you using genuine Canon toner?
          • tech28
            • Jun 2013
            • 434
            Re: Canon ir 4580i
            Just replace drum/dv unit, or look in YouTube on how to rebuild those drum units and clean out, replace drum blade if drum is good, or just replace both, make sure you clean drum charge roller good, you will get great color.
            • Service@PRT
              • Oct 2016
              • 181
              Re: Canon ir 4580i
              Yep.. seems the client is using compatible one. All is good now. After replacing drum unit and geniune toner..
              • tinnyjay
                • Oct 2009
                • 663
                Re: Canon ir 4580i
                Magenta drum unit is the first one that consumes first of all drums. If you changed 4 drums at the same time, do not wonder if magenta finishes first.
                Just change the magenta drum unit because everything else is ok.
                "Who loves the roses,must also bear thumbs"
