iR 2018, can't enter service mode, system won't start, stuck at loading bar
  • darkocg88
    • Jan 2018
    • 63
    Like thread title says, on iR 2018 system won't start, cant enter service mode, loading bar during the start up just keeps starting over.
    Thanks for help in advance.
  • roho
    • Mar 2009
    • 844
    Re: iR 2018, can't enter service mode, system won't start, stuck at loading bar
    Since this device has no hard drive, I would suspect the image process pcb.
    • copier tech
      • 8213
      Reflash the system software/firmware its comon issue on this model.
      โ€‹
      • darkocg88
        • Jan 2018
        • 63
        First thing that came to my mind but im unable to enter service mode due to machine not booting up but being stuck at loading bar while booting.
        Any way to flash it without service mode?
        • darkocg88
          • Jan 2018
          • 63
          I suspected as much, but wanted to look at other solutions before getting a new ip pcb
          • copier tech
            • 8213
            How about starting in safe mode will it boot from a fw flash drive like the bigger Canons do?
            โ€‹
            • darkocg88
              • Jan 2018
              • 63
              No, can't boot from USB with fw. Suspecting physical dmg on ip pcb board.
              • Hopper2
                • Aug 2017
                • 14
                Service mode may be different than other Canons?
                for 1022 = Enter the Service mode. (Main Menu > 2 > 8 > Main Menu)
                2 and 8 not same time.
                • Blizzoo
                  • Aug 2013
                  • 611
                  It's been a long time since I have done a FW update on this model...you need SST app and FW, start the machine in download mode (2+8 and Power) and flash it from your PC through SST connected to machine via USB cable? I may be wrong about this
