Printing issue with canon ir-adv-c5550
  • gksapple
    • Apr 2014
    • 116
    [CQ] Printing issue with canon ir-adv-c5550
    Hi
    print out is not looking as orginal file in cadd diagrams saved as pdf .in canon ir-adv-c5550.
    File is tested with ufrii and ps driver out put is differ from original but the same file is printed on toshiba mfp its out put is same like
    original file ,
    kindly have a look on the attached file and suggest your comments
  • shazza
    • Nov 2009
    • 96
    Re: Printing issue with canon ir-adv-c5550
    Hi try Below .
    I have had similar problems when goimg down Driver route and Autograd with correct media type Resolved
    [Cause]
    These may be due to the correction of image gradation density characteristics that change by the environment change or deterioration of photosensitive drum failed to keep up.
    [Remedy]
    If the printed result of copying the image is significantly different from the original, this may improve by correcting the gradation. Implement by following steps.
    • Select Settings/Registration > Adjustment/Maintenance > Adjust Image Quality > press "Auto Adjust Gradation".
    • Select the type of paper to adjust > press [Full Adjust].
