Canon imagerunner 2420 (Update Fimware *BIOS MODE*)
  • innokileo
    • Mar 2017
    • 7
    [Error Code] Canon imagerunner 2420 (Update Fimware *BIOS MODE*)
    Hello,
    Please i need help i have Canon imagerunner 2420 copy machine error mesage (Update Fimware *BIOS MODE*)
  • Practic
    • Oct 2014
    • 56
    Re: Canon imagerunner 2420 (Update Fimware *BIOS MODE*)
    Is it recognized by computer via USB?
    What's happened from customer`s words?
    Sent from Ericsson DBH 1001.
    • Practic
      • Oct 2014
      • 56
      Here is what you can do. That helped me once.
      You need to get to mainboard and find there flash memory. In my case it was chip - 25Q64BVFIG. It contains firmware for that machine.
      Then - need to desolder it, reprogram using programmer with support of that type of schemes and solder it to mainboard again.
      Downbelow will be a link for dump to download (must mind you - that Canon iR-2420 was in Russia and I'm not sure about differences between US/Canada and European firmwares. Just to let you know that beforehand - that there might be some problems to show up. But I suppose - since machine will finish loading inner software and comes to ready state - you can just figure it out by playing with local/country settings). These are photos before and after (connector melts a little)
      - About dump - it's ready to use with your programmer - it's been taken from newly installed machine (not by me - but from guys from similar Russian tech forum).
      с нового аппарата ir2420.BIN / Облако Mail.Ru
      - About programmer - mine is - TL866A - pretty simple and cheap
      Good luck! Hope that will works for you!
      • innokileo
        • Mar 2017
        • 7
        Hello patric
        Usb is not recognized by pc
        • copier tech
          • 8188
          Originally posted by Practic
          [ATTACH=CONFIG]38741[/ATTACH]
          [ATTACH=CONFIG]38742[/ATTACH][ATTACH=CONFIG]38743[/ATTACH]
          [ATTACH=CONFIG]38744[/ATTACH]
          Wow this is a bit drastic, have you tried simply reflashing the firmware?
          • Practic
            • Oct 2014
            • 56
            I have been trying just to reflash firmware, but as I remember now - there is some sort of special download mode (when you holding some sequence of buttons while switching main power on), when device can accept firmware file. And at the same time - Canon program must be running to find your plugged in device and give you permission to upload firmware. And the reason why I was going the way I wrote above - device wasn't recognized by Canon uploading firmware program.
            But yeah - easy way here is to start from trying luck with that program.
            • innokileo
              • Mar 2017
              • 7
              I read online that there was a sst program, downloaded it and I missed the firmware thats I asked you to send the download link
              • copier tech
                • 8188
                You use the sst tool to upload the firmware
                Canon SST V4.32EV
                • Practic
                  • Oct 2014
                  • 56
                  Hey innokileo, what are first 3 letters of your serial number on machine? Where that device locally? And - is there any chance that you can find what version of firmware there was before?
                  • patrickdaud25
                    • Apr 2020
                    • 3
                    Hello,
                    You just buy firmware firmware and update from copytech this is how I do for this problem
                    • gah36
                      • Jan 2021
                      • 2
                      Re: Canon imagerunner 2420 (Update Fimware *BIOS MODE*):
                      hello, please i need help i have canon imagerunner 2420 copy machine error mesage (update fimware *bios mode*)
                      en algerie ghamri 0662137239
                      • copier tech
                        • 8188
                        Firmware Update - Printer & Copier Firmware
                        • gah36
                          • Jan 2021
                          • 2
                          En algerie ;ghamri 0662137239
