Ir advc5051
  • bomberi
    • 107
    Ir advc5051
    hello, i have an ir adv c5051 copier with no possible To use the ADF. It la the ADF one pass. Thanks for helps.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Ir advc5051
    Any massage or error code?Are you a tech?
    • bomberi
      • 107
      Re: Ir advc5051
      thanks i'am canon french technician but my english is poor,I have not any error code . the messag is: "impossible to use the feeder", the feeder is one pass for recto-verso . In the service mode there is no feeder but I have (copier, sorter, Fax). I can print, do copy on the glass.
        • 16083
        Re: Ir advc5051
        In service mode
        make sure SCANTYPE is set correctly in SERVICE MODE > COPIER > OPTIONS > CUSTOM > SCANTYPE = 1 for a single pass DF.
        When C5030 is using a recirculating DF, set SCANTYPE to 0.
        • bomberi
          • 107
          Re: Ir advc5051
          Thank you for your answer I try what you say and now it work very well.
            • 16083
            Re: Ir advc5051
