canon ir 6055 6065 6075
  • crisjala
    • Feb 2018
    • 3
    [Dead] canon ir 6055 6065 6075
    Hi! my canon ir advance 6075 series had this problem there is no display when you turn ON but the main power LED lights on, mostly the easiest solution is to replace the main controller pcb 1 with a new one which is very expensive is there other solution? Is the main controller pcb's repairable? thanks
  • teckat
    • 16083
    Re: canon ir 6055 6065 6075
    Nation-Wide Repair Service
    16151 Foster Street
    Overland Park, KS 66085
    Customer Service: 1-866-655-8676
    Fax Number: 913-387-1815
    Technical Support: 1-800-798-1814
    Hytec Dealer Services
    3600 Vineland Rd Suite 121
    Orlando, FL 32811
    Customer Service: 1-800-883-1001
    Phone Number: 407-297-1001
    Fax Number: 407-297-4310
    Technical Support: 1-888-883-2001
    Canon USA Repair Services
    Canon Virginia, Inc.
    933 Achievement Way
    Newport News, VA 23606
    Technical Support: 1-800-528-2830
    • copier tech
      • 8131
      Before you start ordering boards try reseating all connections, always worth a try & its free!
