i am looking for a hard drive for an ir 5000. from canon this is a pricey part. does anyone know of a possible substitution for this? does anyone have a good used available? please help. thanx
canon ir 5000 hard drive
Tags: 161, 183, 5000, act, address, address book, assist, canon, canon ir 5000, canon ir5000, click, control panel, copier, drive, email, email address, executing, failure, gmail, hdd, ignore, ir500, ir5000, left, message, modify, panel, parts, purchase, register, scan, send, stuck, substitute, substitution, sys, system, time, unit
The same goes for 99% of Canon IDE drives.
You can buy your own 5.25 HDD and use SST to load the software yourself.
Try to replace the drive with one of the same or similar capacity...modify the .itf file,format the drive,load the software and away you go. -
jtymabel:
Can you please advise your email address or email me at dbmoylan@gmail.com. Need to purchase Canon IR5000 parts. Thanks.Comment
jtymabel:
Can you please advise your email address or email me at dbmoylan@gmail.com. Need to purchase Canon IR5000 parts. Thanks."Once a King, always a King, but once a Knight is enough!"
jtymabel:
Thanks guys - am new to this forum & had to register to be able to send private message (done).
Thank you.Comment
check e bay link/ iR5000 HDD / + it is loaded with firmware
$395.00 US + free ship
CANON ImageRunner 5000 FY1-1200 HARD DRIVE & SOFTWARE - eBay (item 230466616179 end time May-25-10 08:16:10 PDT)**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Would the software for the IR5000 be same as IR5000i? I've a 5000i unit that pushes scanned images to the computer.Comment
Teckat, thanks for your quick replies. Do you have any experience with the IR5000 or IR5000i HD reliability? Do you hear of these HDs failing more often than other models?
Also, if the defragment white block is staying in the upper left corner of the display after pressing 1&9 upon powering up the copier, is there any other way to try and revive/reboot the system to operational status? Worked a few months ago, but now seems to be stuck in the upper left corner without moving.
Thank you.Comment
HD's can fail anytime , usually you can recover from a 602-0003 with a de frag/
HD-Check can also be executed from service mode. This function is located under COPIER>FUNCTION>SYSTEM>HD-Check. It will run in combination with a Check-TYPE. Check-TYPE will determine the partition being checked. If Check-TYPE:0, the HD-Check will scan the entire hard drive. Please note that HD-Check will display 100% almost immediately and will flash 100% for about 15 to 20 minutes until the entire hard drive is checked. During that time it seems as if the imageRUNNER is locked. DO NOT POWER OFF the unit until HD-Check=OK!**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Thanks Teckat. System is running again after retrying 1&9 today - started to defrag as suppose to vs. yesterday when it just locked. I understand that the HD-check you've detailed is from the display panel. I can only see "additional functions" button & cannot find the HD-check software function. Can you pls. assist. Thank you.Comment
you have to access it in service mode/
Starting Service Mode and Making Selections
1) Press the user mode key (*) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key (*).
select>COPIER>FUNCTION><SYSTEM>
CHK-TYPE
Used to specify partition number when executing HD-CHECK or HDCLEAR.
<Operation method>
1) Select this item.
2) Use the numeric keypad to select the desired partition number.
0: Check and restore all bad sectors on hard disk
1: Image storage area
2: General-purpose file storage area
3: PDL file storage area
4: Firmware/Address book/Filter storage area
• General-purpose files include user-set data, log data, PDL spool data,
and management information for image data.
3) Press the OK key
HD-CHECK
Performs partition check and restoration process specified by CHK-TYPE
item.
Operation 1) Select this item.
method 2) Press the OK key.
3) The result is displayed (1: OK, 2: NG (hardware), 3: NG (software),
restored sectors/substitute sectors
HD-CLEAR
Initializes partition specified by CHK-TYPE item.
Caution The following must be kept in mind and the user must be properly informed
of the fact when using CHECK-TYPE:
0: entire HDD → no operation occurs (to initialize, use the SST)
1: image storage area → removes image data
2: general-purpose file area (user settings data, various log data, PDL spool
data, image data control information) → initializes files
3: PDL-related file storage area → removes font data, requiring re-installation
4: firmware, address book, filter storage area → no operation occurs (to
Operation method
images..jpgwarning
If you execute <HD-CLEAR> after selecting 1 (image storage area) or 3
(PDL file storage area) for the <CHK-TYPE> item, the initialization process
is performed after the power is turned OFF/ON.
The initialization process takes about 5 minutes. A progress bar slowly advances
to indicate the progress during this time. Never turn the power OFF
during this time.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Thank you Teckat for your help! Will do HD check as suggested since this is 2nd 602-0003 error problem in past 5 months.Comment
