IR2800 finisher J1 and Lifter problem
  • dadjo
    • Jan 2018
    • 35
    #16
    Re: IR2800 finisher J1 and Lifter problem
    Originally posted by teckat
    See link attach-
    Service Bulletin------iR2200/2800/3300 Series
    Measure Against Cassette Lifter Failure to Rise
    http://www.bosscan.cz/podpora/Techni...ir3300-006.pdf
    youtube video ----click on pic
    [ATTACH=CONFIG]39145[/ATTACH]
    • teckat
      • 16083
      #17
      Did you read the attached pdf iR3300 Service Bulliten on Lifter Issue ????
      • copier tech
        • 8133
        #18
        I spent many years working on this model & this fault.
        This lifting issue can have many different causes as listed in the pdf.
        However the most common reason I saw was the spring mounts would snap off, since this mount was part of the frame it cant really be repaired, however I did have some success gluing it back on.
        But most times I would simply replace the complete PF unit.
        • dadjo
          • Jan 2018
          • 35
          #19
          • teckat
            • 16083
            #20
            Did u READ---Service Bulletin
            Subject: Measure Against Cassette Lifter Failure to Rise
            Reason: Loose engagement of lifter arm claws and ratchet gear
            • dadjo
              • Jan 2018
              • 35
              #21
              • teckat
                • 16083
                #22
                ?- forget about lifter for now--------
                Does the printer see the paper trays as present on panel
                If so> do u get an add paper message
                if not> u have some type of signal problem
                • dadjo
                  • Jan 2018
                  • 35
                  #23
                  Well, it shows this screen
                  I do get a message saying (add paper) and the tray signals blink as I insert the paper trays. When I insert the paper trays, the machine makes the usual sounds.
                  • dadjo
                    • Jan 2018
                    • 35
                    #24
                    [ATTACH=CONFIG]39183[/ATTACH]
                    • teckat
                      • 16083
                      #25
                      mind-reader real.jpg I will keep thinking and send u some thoughts
                      One thought----can u print from the Bypass Tray
                      Good Troubleshooting requires u to follow a Procedure of Checks and Inspections & Re-Checks ---lessons learned a long time ago
                      Seems like SL 1 is the key to the lock (operation)
                      The lifter fails to move up (pickup from the cassette).
                      1. Releasing lever (for pickup roller).
                      Push in the releasing lever toward the rear. Does the descent movement of
                      the pickup roller stop?
                      NO: The releasing lever (spring) is displaced or deformed. Correct or
                      replace it.
                      2. Lifter gear retaining lever lock.
                      When the cassette is slid in, is the lock of the lifter gear retaining level released?
                      NO: Correct the locking mechanism of the lifter gear retaining lever or
                      replace it.
                      3. Lifter gear, Lifter gear retaining lever, Lifter ascent lever.
                      Is any of the gear faulty (damaged)?
                      YES: Replace it.
                      4. Lifter drive assembly
                      Is the gear of the lifter drive assembly damaged or subject to foreign matter.
                      Is the drive belt faulty?
                      YES: Replace the gear/belt. Remove the foreign matter.
                      5. Pickup roller descent solenoid (SL1C).
                      Execute the following in service mode: code 6 of COPIER>FUNCTION>PART-CHK>SL; i.e., SL-ON.
                      Is the solenoid drive voltage present at J1604 of the pickup PCB? (J1604-4: 24 V, J1604-1:
                      PICKUPSL*)
                      YES: The pickup roller solenoid is faulty. Replace it.
                      6. Pickup PCB, DC controller PCB.
                      Execute the following in service mode: code 6 of COPIER>FUNCTION>PART>CHK>SL; i.e., SL-ON.
                      Is the solenoid control signal present at J302A-5 of the DC controller PCB? (J302A-5:
                      FDOWN_SL*)
                      YES: Replace the pickup PCB. ( Cassette pickup PCB )
                      NO: Replace the DC controller PCB.
                      Moving Up the Lifter
                      When the main power is turned on with the cassette set in the machine or the cassette is slid in while the machine is in standby state, the pickup roller shaft moves down to push
                      down the lifter trigger lever.
                      The cam is released when the pickup roller shaft pushes one side of the lifter trigger lever, and the drive from the main motor (M1) moves up the lifter.
                      When the cassette is slid into or out of the machine, the following takes place:
                      Moving Up the Lifter/Moving Down the Pickup Roller Shaft (cassette slid in)
                      1) Moving Down the Pickup Roller Shaft
                      With the power on, when the cassette is slid into the machine, the pickup roller moves
                      down until it comes into contact with the paper surface as follows:
                      • The cassette rear end pushes in the lever 1 of the pickup unit.
                      • When the cassette size detection mechanism goes ON, the main motor (M1) and the
                      pickup solenoid (SL1) go ON to swing the pickup lever.
                      Detecting the Presence/Absence of Paper Inside the Cassette
                      When the cassette runs out of paper, the paper detecting lever falls through the detecting hole of the cassette, causing the light-blocking plate linked to the lever to block the light of
                      the photointerrupter (Q1604 for cassette 1; Q1605 for cassette 2).
                      • dadjo
                        • Jan 2018
                        • 35
                        #26
                        [ATTACH=CONFIG]39196[/ATTACH] I will keep thinking and send u some thoughts
                        Yes I can print from bypass tray. The Motor M1 is working. These plastics should be transparent...
                        When I simulate the insert of a tray by hand, the lifter works fine with all the tooths, so it is doing contact. but the motor M1 is working. Not easy...
                        • teckat
                          • 16083
                          #27
                          OK
                          so one of those PCB's need to be the issue or harness connection signal
                          • dadjo
                            • Jan 2018
                            • 35
                            #28
                            OK
                            • dadjo
                              • Jan 2018
                              • 35
                              #29
                              Hi people. So the problem was the Paper pickup assembly. It seems that when a spring snaps inside this assembly, the gears go crazy and it is not possible to sincronize them in the correct order. but now all is going good. Thanks you for your help.
                              • teckat
                                • 16083
                                #30
