Ir2200
  • logonjim
    • 136
    Ir2200
    Hi Guys I know this is a very old machine but slight problem The machine takes a while to warm up and then when you make a copy it does not come ready for about 10 seconds after copy is delivered..Hard drive problem i am thinking?
  • roho
    • Mar 2009
    • 844
    Re: Ir2200
    usually you get a error code for HDD issues, usually. How old is the fuser, wonder if it is keeping the right temp. Could be a few things, what have you done or tried?
    • logonjim
      • 136
      Re: Ir2200
      I have checked out the fuser gets to the temp that is required film and rollers are ok and No errors at all.Looks like a temp. issue but as I said reaching proper temp.
      • teckat
        • 16083
        Re: Ir2200
        Did u check wall voltage outlet for correct supply ?
        • logonjim
          • 136
          Re: Ir2200
          Hello Teckat No I have not checked that out . The machine is in an office on its own and other electrical items working ok I might try a change of fuser if I can locate one tks for tip
            Re: Ir2200
            check the wall voltage before replacing anything... drops or spikes can really muck up the works.
            • logonjim
              • 136
              Re: Ir2200
              Ok Guys wall voltage ok constant at 230V the machine produced the dreaded error code today E602-003 so must have been a Hard Drive problem all along I removed and cleaned the Dimm so I guess that is the end of a great machine as there are no Hard drives available I cant even get into the service mode to do a check disc
              • teckat
                • 16083
                Re: Ir2200
                Try holding down 1 and 9 key while powering on printer, this puts printer hdd into defrag mode
                Shows white blocks dropping on menu, u may get a NG if HDD is bad
                Old refurbished had available online.
                Amazon.com: Buying Choices: HDD Hard disk for IR2200 2800 3300 ir2800 ir3300 FK4-0927-000
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4653
                  Re: Ir2200
                  I may have a hard drive with the IR2200 system software installed on it. PM me if you still need it?
                  • bomberi
                    • 107
                    Re: Ir2200
                    Hi, you can change the HDD and download the firmware.
                    • copier tech
                      • 8133
                      Re: Ir2200
                      Classic HDD issue, sometimes you can hear the drive clicking or struggling to spin hence slowing the machine & making it unresponsive.
                      This is the list of HDDs model you can use.
                      You can actually edit the HD format file & use ANY hdd if you wanted.
                      iR2200 hdd list.txt
                      • logonjim
                        • 136
                        Re: Ir2200 Hanging
                        Hi Guys I managed to get a hard drive for the machine and is working perfectly again . Thanks again.A great box but Canon decided to end its life way too soon as it was too reliable.
