IR ADV 6055 jamcode 0103 -ps24
  • Midhun0100
    adv 6055 paper jam 0103 - ps 24
    IR adv 6055 jam 0103
    Hello
    one of our 6055 machine 0103 paper jam occurs.paperalways stuck on the same place (see the attached image) .I replaced entire right side cover,first pick up
    assembly and tried to cleaned the rollers near the vertical path sensor, but still jamming.
    Any help will be welcome.
  • NorthW
    • Jul 2017
    • 55
    Re: IR ADV 6055 jamcode 0103 -ps24
    Is that sheet on the wrong side of that black diverter??
    Do all other trays, 2,3,4 feed OK, duplex as also?
      • 16083
      Hello
      is issue > as asked already > from all paper feed locations ?
      make sure u inspect and clean any of those Gold Colored Bushings- black gunk build up inside causes jam delay issues.
      Tech Tip: never lube these bushings> causes a reaction with material used in bushing > lesson learned a long time ago with these Canon NP/iR/CLC/iRADV-C_Printer Bushings.
      • Midhun0100
        no,its in the right side.except tray 2 , all other trays having the same issue
        • Midhun0100
          tray 2 is working ,all others having the same issue.i already cleaned those bushings with gold colored.but still the same
