Re: Reviving Canon IR c5180
Complete Re-Install of the H1 > just as if u were first doing a set up.
First-Remove all connections cables(I/F Communications Cable,Cross Ethernet Cable, & Network Cable from H1 to Copier/also unplug H1 power cord.
*NEXT>>>>follow below EXACTLY AS SHOWN
1. Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
2. Select Copier > Option > Int-Face > IMG-CONT.
3. Change the setting of IMG-CONT back to "0"
4. Hit OK and (& follow the normal shutdown procedure of Printer) then Re-Boot the Copier.
5. Re-Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
6. Change the setting of IMG-CONT back to "3"
7. Hit OK and ( again >follow the Normal Shutdown Procedure of Printer)
8. With Printer "OFF", u now Connect all of the 3 Cables that were previously removed.>don't forget H1 POWER CORD--
9. Now > Power back up Printer
10. At the Control Panel, press [Printer] tab.
11. Press [Printer Status/Settings].
12. At the Languages Setup screen, select the name of the language you want to use, and then select OK.
Wait a few minutes.
13. Input of password Fiery .1 (exactly as shown )
14. In response, the machine will automatically show the Settings menu.
15. Be sure to at least select the following and make the appropriate settings in the indicated order:
[Server Setup], [Network Setup], and [Printer Setup].
Checking the Operation After Making the Settings
Print out a test page and a settings page as follows to make sure that all settings have correctly been made on
the machine and its host machine and that all connections are normal------
1) Press (=>) displayed at upper right on the LCD of the connecting device.
2) At the Control Panel, press [Print].
3) Press [Printer Status/Settings].
4) Make the following selections on the LCD:function>print page>test page/configuration.
Hopefully this Procedure will get u up and Running/Works about 90% of the time
Wait a few minutes.
