IR3300 developer unit problem
  • princepriyu
    hi friends i'm having a problem with canon ir-3300 developer unit. it is printing uneven, dark on one side and very light at the buttom side please refer the image & developer unit i'v checked the magnet roller, its fine please suggest IR 3300 (2).jpg IR 3300 (1).jpg IR 3300 (3).jpg
    • 8164
    Re: IR3300 developer unit problem
    Looking at your dev unit it is NOT fine I can clearly seen the toner is uneven on the mag roller causing your uneven prints.
    Replace the developer unit & fit a new toner.
    โ€‹
    • Brian8506
      • 1664
        • 23008
        It doesn't look so fine to me. Where's the toner coverage on the mag roller? And where is the teflon coating on the mag roller? =^..^=
