replace hdd
  • vinhsesco
    • Jun 2009
    • 30
    [Dead] replace hdd
    Dear all.
    I have canon ir 6255 damaged hdd machine. i have replaced the new hdd but no firmware update you can help me. vinhsesco@gmail.com. Thank you very much
  • copier tech
    • 8131
    Re: replace hdd
    Originally posted by vinhsesco
    Dear all.
    Firstly you need to fit the correct HDD, just any hard drive wont work.
    We have the firmware on our site below.
    Copier Firmware - Canon Firmware, What Is Firmware, Ricoh Firmware
    • teckat
      • 16083
      Re: replace hdd
      Dear all.
      Did u have an ERROR CODE
      explain above u have no firmware / or update failed
      HDD needs to be Formatted with SST/or USB--- iRAdvanced 6255 Firmware
      The part numbers for the Hard Disk Drive for this series machine have been updated (2015).
      The new numbers are as follows:
      FK2-9008-000 = iRA 6055 / 6065 / 6075
      FK4-1550-000 = iRA 6275 / 6265 / 6255
      imageRUNNER ADVANCE 6055 / 6065 / 6075 / 6255 / 6265 / 6275 / 8085 / 8095 / 8105 / 8285 / 8295 / 8205
      HD Format Error
      When trying to format the Hard Drive by holding 2 & 8 down OR single mode through SST, you get an "ERROR" message when executed.
      The HD format script resides on the Flash Rom of the machine and can become corrupted. The machine didn't have an error code and would boot up, but would not allow firmware to load because HD Format Error would error. Obtained a new, blank Flash ROM PCB from Hardware Engineering to resolve the issue.
      • vinhsesco
        • Jun 2009
        • 30
        Re: replace hdd
        HD Format Error
        hdd old no detect, i need to replace a new hdd what to do. Thank you very much
        • djmic
          • Sep 2019
          • 6
          Re: replace hdd
          HD Format Error
          Hi teckat! Same problem here! for IR advance 6255 need hdd replacement. Pls send a tutorial step by step on how to install firmware for new hdd. Thank you in advance!
          • TSS
            • Jul 2018
            • 27
            Re: replace hdd
            You need to format hhd, install firmware
            • djmic
              • Sep 2019
              • 6
              Re: replace hdd
              Thank you for response Tss! Do you know the step by step procedure using sst tool then install the firmware in IRA 6200 series
              • teckat
                • 16083
                Re: replace hdd
                Procedure to install USB System Software to a USB Flash Drive
                1. Download "USB" System Software for the iR-ADV C6275 Series for example:
                iA6275_v18.02.01.zip”
                2. Open the “USB_iA6275_v18.02.01” folder and place the “iA6275” Folder and “All HDFormat” files
                onto your USB Flash Drive.
                3. Done
                USB Flash Drive:
                Flashing the System Software by use of a USB Flash Drive is supported.
                SERVICE MODE > COPIER > FUNCTION > SYSTEM > DOWNLOAD
                Select Format first
                then ALL
                • yelse
                  • Apr 2012
                  • 8
                  Re: replace hdd
                  I also experienced the same thing please send me the IR ADV 6275 firmware.
                  My email: yeelsee@gmail.com
                  Thank you very much
                    Re: replace hdd
                    My email: yeelsee@gmail.com Thank you very much
                    did you READ the whole thread? firmware is not all that you need..
                    have you checked the HDD in service mode to make sure it is a viable unit?
                    have you reformatted the HDD?
                    bet you didn't even backup any NVRAM!
                    get the manual
                    RTFM!!!
                    • jio9000
                      • Mar 2020
                      • 26
                      Re: replace hdd
                      HD Format Error
                      i have an imagerunner advance c5235a giving the same issue , where can i get a flash rom for my model ?
