Canon IRA C2225 Red Streak While Scanning Through Doc. Feeder
  • doug
    • Dec 2011
    • 198
    Hi Guys!
    Customer said there is a red sripe on copies when she feeds throgh the doc. feeder only sometimes...I went there and ran several with no problem BUT then there was the streak only this time it was green!
    Has anyone ever seen this?
    Thanking all of you in advance
    Doug
  • sal
    • Dec 2011
    • 19
    Re: Canon IRA C2225 Red Streak While Scanning Through Doc. Feeder
    how old are your drums and is it only when using the feeder try running a few from the glass drums on this machines have a lot of problems and they don't last long
    • roho
      • Mar 2009
      • 844
      Originally posted by doug
      Hi Guys!
      Doug
      Slit glass needs a good cleaning, sometimes a suspect bit of dust may be picked up by the scanner as a color as opposed to a traditional black line. Clean the slit glass, even remove it and wipe on both sides, then perform the DF WL adjustments.
      • dan7777
        • Dec 2012
        • 680
        Exactly correct. Dirty slit glass could be red, green, blue always in color but black copy would be black line. I try and train every customer to clean that glass. They seem to think it is copier problem not their dirty office and paper.
        • JPiek
          • Oct 2014
          • 435
          Often been to customers complaining about lines after they 'cleaned' the glass. had to explain often softly wiping is not cleaning...
          Johan
          • copierspluswwllc7365
            • May 2019
            • 5
            Canon Imagerunner Advanced 4225i
            I was wondering does anyone know how to Shut Off this Message being Displayed on this Canon Ir 4225 Copier.: Clean Slit Glass) I cleaned the slitglass and the glass on the exposure lamps. I shut off the unit and the message goes away but,then returns. Doany know how to shut off this message?
            • JPiek
              • Oct 2014
              • 435
              Do you have lines on the copy ? Clean the glass. If not, clean the opposing roller and White strip on the bottom of the ADF lid. Spots make the msg come up too...
              Johan
                • 8131
                Strip & clean the CCD this unit has mirrors that get dusty. Plattern glass off then two screws, lift up the LED ass'y to gain access to the mirrors.
                After cleaning run CCD adjust in service mode. (refer to the service manual)
                • hidius
                  • Jun 2015
                  • 128
                  the only time I've ever had color lines while scanning from feeder is when there's a little chip on the slit glass.
