Canon IRA C2020/2225 Not Receiving Faxes
  • doug
    • Dec 2011
    • 198
    Hi guys!
    I have a customer that cannot receive faxes ....they they can send fine.
    This problem has tried to be resolved by switching out 3 different model machines (IRA2020,2225 and an IRA5255) all doing the same thing.
    I told the customer to contact Xfinity for this problem, and they say of its not their fault.
    Is there a setting on the Canon IRA s that need needs to be set? It seems like the only time I have this problem is with Xfinity customers.
    Has anyone else seen this problem?
    Thanking you in advance,
    Doug
  • guitar9199
    • Sep 2016
    • 1099
    Re: Canon IRA C2020/2225 Not Receiving Faxes
    Originally posted by doug
    Hi guys!
    Doug
    The FIRST thing I try is connecting a portable phone to their line and listen to the dial tone. If they have voicemail assigned to that line, it'll give you a "Stuttering" (4-5 beats) dial tone before it goes steady. If the incoming line does that, the fax will never connect!!
    If you get a steady dial tone from the start, next thing I'd do is disable ECM. Then follow though with the usual suspects... Reduce TX/RX speed, use default G3 protocol, deactivate JBIG, etc...
    • copier tech
      • 8114
      There are a few simple tests can be done before swaping out the machine!
      Call the Canon from your mobile, does it answer?
      Plug in a phone into the wall socket can you make & receive calls?
      Can they receive faxes from other fax machines/numbers?
      99% of fax issues I see are caused by line faults, most common cause is noise on the line.
      • nmfaxman
        • 1702
        Call your mobile from fax machine.
        Check caller ID.
        They could be giving out wrong phone #.
        Seen it many times.
        • teckat
          • 16083
          RX Speed
          Try and Select a slower speed.
          You can select [33600 bps], [14400 bps], [9600 bps], [7200 bps], [4800 bps], or [2400 bps].
          • JPiek
            • Oct 2014
            • 435
            I had the same issue with a IRC ADV V2020, turned out i missed a (not to Obvious) setting :
            All credits go to Skynet
            Johan
            • songela
              • Mar 2008
              • 216
              If they can SEND from same terminal that means it's all fine with the line.
              Then the two most likely causes are:
              1. Country settings: Make sure you select the correct country settings that apply to your locality. If you are not sure of which type, consult someone at the Exchange.
              2. Line Jack: (this is most likely) British type Line Jacks usually come fitted with a capacitor and that will prevent fax RX completion. Open up the Jack and if you find a capacitor replace it with one without any.
              However though, couldn't figure out faxes still have got some happy days to go!!
