IRC2380i - Only Green LED but no touch screen
  • dj_beirut
    • Aug 2018
    • 14
    [Dead] IRC2380i - Only Green LED but no touch screen
    Hello.
    I am having an issue with the irc2380i. removed the drums and cleaned around them etc but after putting them back together now the copier will not boot.
    It sounds all good when i turn it on but the screen is off and only the green led is on. The printer is offline so i can't reach it from the network.
    totally lost here, any ideas that will put me on the right track would be greatly appreciated.
  • aAandy
    • Apr 2012
    • 370
    Re: IRC2380i - Only Green LED but no touch screen
    did you shut the machine down correctly? you may have killed the HDD
      IF I was a betting man... the answer to that question would be .... uuuuuuuuhhhhhhhh noooooooooooo
      The HDD?
      how much is that?
      does it need new firmware?
      do you have firmware for me for free?
      how do I do that?
      do i need to do anything else?
      is there a service mode i need to enter to do this?
      how do i do that?
      can you give me the manual?
      sorry just trying to save 35 posts in the thread
      • aAandy
        • Apr 2012
        • 370
        The HDD?
        how much is that?
        how do I do that?
        how do i do that?
        wife's looking at me wondering why i'm laughing so much - thanks for the levity
        • songela
          • Mar 2008
          • 216
          Originally posted by dj_beirut
          Hello.
          There is no direct relation between what you did and the BOOT FAILURE fault, it's more of a coincidence.
          This will usually result from poor contacts of one of the PCI Cards on the Main Controller PCB (can't correctly remember the particular one).
          1. Take out relevant covers.
          2. Unplug all the Cards from the Main Controller PCB.
          3. Clean all slots thoroughly.
          4. With a dry cloth, rub the contacts of all the Cards.
          5. Plug back the Cards making sure they are seated properly.
          6. Power up and hopefully you are back to life.
          • JPiek
            • Oct 2014
            • 435
            Sh*t happens, 2380 is 'rather old' wouldn't advice to throw a dime at it, you might loose it...
            Johan
            • dj_beirut
              • Aug 2018
              • 14
              No i did not shut it correctly. and yes @Phil B. is right. i don't have the service tools nor do i know how to go forward.
              i have opened it up and cleaned all the slots etc.
              But a link or a wiki or a quick explanation on the HDD part would also save this thread 35 comments.
              Thanks in advance guys and sorry for being such a noob.
              • dj_beirut
                • Aug 2018
                • 14
                Sorry for being a noob. No it was not shut down correctly.
                this started after opening the drum drawer and tried cleaning there. i am not sure if it is related to that. All drums were removed and cleaned and then put back together.
                @phil b. is also right. i don't have the tools to do the HDD reinstall. So if there is a wiki, or a guide / document i can read on that would help me a lot and save the thread a lot of stupid questions. ofcourse a link to the service tool software.
                i made a video of the machine booting up as it might give an indication of what is wrong.
                canonirc2380i.mp4 - Google Drive
                Thanks in advance guys and sorry again for being a noob.
                • dj_beirut
                  • Aug 2018
                  • 14
                  btw disconnected HDD to see if it produces an error. Screen still dead black and only green led.
                  i slide out the process unit and try starting it up and still no go.
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5015
                    Do as the Songela said.
                      Glad to hear it made your day.
                      Just tooo many times in my life in this industry, I have had techs under me ( yes most times have moved to MGT pos quick ) that don't read, can't comprehend or just don't wanna finger it out for themselves. Hence my rant
                      • dj_beirut
                        • Aug 2018
                        • 14
                        I am sorry to hear about your experience with Techs that are useless. But some of us really wants to read and figure out and fix it ourselves. For that we need the help of experts like yourself with the tools and experience to guide us or at least put us on the right direction.
                        If you would like to help i would greatly appreciate that and even pay if the solution is found. If not please don't hijack the thread.
                        I bought this machine and bought alot of parts for it and it has cost me more than it should and yet canon is not interested in sending a service guy. so i really want to figure it out and fix it. Please.
                        • dj_beirut
                          • Aug 2018
                          • 14
                          Thanks for the reply.
                          All the pci cards are removed, cleaned and reinserted. Still the same symptoms. Please take a look at the video i posted hopefully it might give an indication of what it could be.
                            [QUOTE=dj_beirut;696849
                            .[/QUOTE]
                            done
                            another to the block list
                            • dj_beirut
                              • Aug 2018
                              • 14
                              did that. did not help
