IRC2380i - Only Green LED but no touch screen
  • aAandy
    • Apr 2012
    • 370
    Re: IRC2380i - Only Green LED but no touch screen
    Originally posted by dj_beirut
    did that. did not help
    i'd put my money on a dead HDD, you're going to need a new drive + all the firmware to go on it - if you have the service manual it should have all the info you need to do the job, but you are going to have fun finding the firmware
    you could try plugging the HDD into a computer as a slave drive and run the manufacturers diagnostics on the drive, you may also be lucky enough to ghost the drive onto a new HDD
    sorry, not much more to tell you
    • dj_beirut
      • Aug 2018
      • 14
      Thanks for the advice. The disk spins up and works fine. i was able to ghost it. but i what i am thinking is if the disk is disconnected it should boot up with an error message that says the hdd is disconnected right? that is not happening.
      for some reason i suspect the MC so i ordered a new one. that seems to have been the problem for several of the cases with the same symptoms even though on different models.
      • roho
        • Mar 2009
        • 844
        Quite likely, if the HDD is bad you typically get a error code, either on the home screen if it boots that far or the DOS screen if it doesn't. Sounds like the controller is toast and not even trying to read the HDD. On the larger color machines I have had a power supply problem, but not with this one yet. I would try the controller first.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          #19
          Did you try with different startups like Safe Mode : (By pressing 2+8, turning on the main power.)
          or boot repair :
          Turn off the power; then, while holding down the 1 and 9 keys, turn on the power so that the WriteAbort
          sector repair routine will start automatically, causing the screen to go solid black.
          1-3 Allow for some time (40 to 50 min). A progress indicator will appear. When the screen turns solid white,
          the repair is over.
          • JPiek
            • Oct 2014
            • 435
            #20
            done
            another to the block list
            OMG Phil, what happened in your life to make you this sour ? I thought his msg. sounded pretty honest. Not everyone on this forum is an expert right from the start.
            Johan
            • zoraldinho
              • Mar 2008
              • 5007
              #21
                dealing with dumbasses.
                this is a social media site ( for the most part ) and I am not required to OR will I continue in convo's with stupid people that EXPECT me to "behave" in the way THEY see fit.
                • guitar9199
                  • Sep 2016
                  • 1100
                  #23
                  I blame "Warning Labels"!!
                  They've succeeded in circumventing Darwin's Theory of Natural Selection, and allowed stupid people to breed.... and vote!
                  Seriously... If you don't KNOW you're not supposed to use an electric dryer in the bathtub or the shower, without a warning label on the device... then you don't need to be in the Gene Pool anymore!!
                  ....sorry.... rough morning!
                  • JPiek
                    • Oct 2014
                    • 435
                    #24
                    Agreed, i've seen my share of fucked-up people too, but i tend to ingore them without warning. Don't feel like spending any energy on 'em.. But again, his msg sounded sincere to me... As I said, not everybody is an expert and not everybody has as much experience as you have (count me out, I haven't done hundreds of copiers either )
                    Unknowing and stupid isn't the same...
                    Johan
                    • JPiek
                      • Oct 2014
                      • 435
                      #25
                      Agreed ! I kinda started to hate equipment from the USA or 'labeled' for use in the USA because of that...
                      In my rearview mirror: "objects in (the) mirror are closer than they appear"
                      On my tomtom (it's an f'ing DUTCH company) navigation each time i start I get a Legal Notic telling me to not blindly follow it's instructions but actualy look at the road (?!?).
                      If you treat ppl as stupid, they will act like their stupid...
                      In Holland if you have been warned once it's your own responsebility after that...
                      Looks like we ARE hijacking this thread, sorry
                      Johan
                      • dj_beirut
                        • Aug 2018
                        • 14
                        #26
                        or boot repair :
                        the repair is over.
                        That did not help
                        I will try to find a new Main Controller.
                        • JPiek
                          • Oct 2014
                          • 435
                          #27
                          I wish you luck !
                          2380i is over 8 years old, here in Holland it's quite impossible to get parts for it.
                          you might try and buy an old extra 2380i for close to nothing, it's save you the hassle of looking for spareparts in the future.
                          Johan
                          • Rockwell
                            #28
                            If you would like to help i would greatly appreciate that and even pay if the solution is found. If not please don't hijack the thread.
                            I bought this machine and bought alot of parts for it and it has cost me more than it should and yet canon is not interested in sending a service guy. so i really want to figure it out and fix it. Please.
                            • Rockwell
                              #29
                              • JPiek
                                • Oct 2014
                                • 435
                                #30
                                Did you just create a new account just to ask the same questions you allready asked ?
                                Doesn't really help in showing you're sincere, does it ?
                                Johan
