Canon Np6030 shut chk error
  • DIMM
    • Nov 2008
    • 44
    I dont find the display message in my manuals, have somebody a hint where i shall check.
    • 22999
    Sorry, that message doesn't mean any thing to me, and I know these machines. Check to see if any error codes are stored. =^..^=
    • imaginGuru
      I don't understand your question?
      The machine shuts off and the display (and machine) goes off?.
      As in most Canons of that generation I'd start checking the fuser unit
      for blown fuses/lamps, etc. also check the main switch.
      • Raoufselwaness
        Expert
        • Nov 2008
        • 75
        Hi,
        if the m/c shuts down with out any code u my check for fuser unit lamps fuses connections plugs etc,also exposure lamp my be burned-it happens with me for NP6035- and if the expo lamp stays on when u switch on the m/c also shuts down with out any code.
        it mentioned in the service manual the page after ERROR codes.
        hope it help.
        • montana
          • Aug 2008
          • 393
          hi.try to check the power source it may not stable.& chek the main switch&power supply board
          i wish good luck for all
          • Raoufselwaness
            Expert
            • Nov 2008
            • 75
            Hi DIMM,
            did u solve your problem?
            u should tell us for the good
            • Canuck
              Tech Specialist
              • 1713
              Hold the power switch on and dont let it click off...probably some e-2.... error or e-8....probably blown exposure lamp
              • DIMM
                • Nov 2008
                • 44
                Thanks for your replies, but i havnt been on that mashine for some weeks, they have a loan mashine from us so far. I post a reply when i have found the fault.
                • code66
                  machine shut off
                  if the machine shut off intermittently,still u can use ur machine,probably the composite power supply hv problem.
                  • bakaoni
                    Door Switch
                    Check the door switch.
