8105 PRO NOT FUSING WELL
  • tinnyjay
    • Oct 2009
    • 663
    Hello!
    I changed both fuser rollers (genuine) but the copier its not fusing well.
    In some caes black pages can wipe out with finger. Also sometimes it happens with text.
    Temperature of ambient its 20-30 grades celsius.
    I set the fuser rollers preasure in maximum also (with 2 screws on the side), but not difference.
    Any help please?
    "Who loves the roses,must also bear thumbs"
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: 8105 PRO NOT FUSING WELL
    OEM toner?
    Correct paper tipe set?
    What is the fuser temp when printing?
    You can change fuser temp in SM.
    • tinnyjay
      • Oct 2009
      • 663
      Originally posted by zoraldinho
      OEM toner?
      Paper is set to plain (80 gsm)
      Printing temperature is:
      FIX U 200 GRADES
      FIX UE 214 GRADES
      FIX UE2 211 GRADES
      I changed COPIER > OPTION > IMG-FIX > FIX TEMP to 2 (+5 grades).
      Still no big difference.
        Originally posted by tinnyjay
        Hello!
        Any help please?
        WHAT component if the fuser detects and regulate the temperature?
        Why did you not do a complete rebuild of the fuser?
        bushings/bearings wear out... so do thermostats/thermistors...
        don't halfass a job.. it will always bit you on the ass... did you perform the NIP-CHECK? No? but you wnet messing with the pressure screws.
        • zoraldinho
          • Mar 2008
          • 5007
          FIX U 200 GRADES
          FIX UE 214 GRADES
          FIX UE2 211 GRADES
          OEM toner?? The most common cause!
          • tinnyjay
            • Oct 2009
            • 663
            • tinnyjay
              • Oct 2009
              • 663
              Yep
