Blank page
  • meldwo
    • Feb 2012
    • 36
    Blank page
    dear all
    I have a problem in Canon IR2525, In the case of copying gives blank page (from ADF and glass) and print is OK
    notes the lamp move and give light Through the copies
    • 23006
    Re: Blank page
    Well, you've narrowed it down to something to do with the scanner.
    Is it set up to scan to a folder or email? Will it do either of those things?
    Are there any error codes? Take advantage of the machines internal diagnostics.
    Most likely it will be a problem with the CCD, ribbon cable, or the image processing board. You choose where to go first. =^..^=
    • meldwo
      • Feb 2012
      • 36
      Re: Blank page
      There are no error, but after copying she gives a message (reservation copies can be mode) and wait 10min and print anther blank page
      • meldwo
        • Feb 2012
        • 36
        Re: Blank page
        I changed ccd , ribbon cable and image processing board
        No other suggestions
          Re: Blank page
          did you even bother to look in the service manual under the " troubleshooting " section?
          • meldwo
            • Feb 2012
            • 36
            Re: Blank page
            dear all
            print and scan to PC is ok but copy gives blank page
