insert drum message Adv. irc5240/50
  • pontiac
    • 420
    [Misc] insert drum message Adv. irc5240/50
    What tells the copier that drum unit is installed is it a sensor or patch on transfer belt being read. We have 4 out of nine units in our rental fleet that are displaying this message no error codes. Drum reinstall or replacement performed still n/g. Simple reboot copier comes back but limited prints maybe 25copies or prints before message appears mainly cyan and magenta drums and one blk drum. Thanks for replys
    Re: insert drum message Adv. irc5240/50
    not sure about THAT model.. most times.. a chip in the consumables (drums-toners etc) and wire 'finger' contacts on the inside.
    are you trying to use pre-installed units into the machine?
    have you cleared counters on the drums etc..
    please explain IN DETAIL what HAS/HASN'T been done!
    • pontiac
      • 420
      HOPING iT WAS THE IMAGE UNIT REPAIR WAS 2 VISITS WITH TWO DIFERENT SETS OF USED DRUMS. JUST INSTALLED NEW ONES COULD ONLY RUN 100 LEDGER TEST PGS. WE WERE LUCKY THE CUSTOMER LET US DO THAT FOR A TEST NO ISSUE WILL FIND OUT NEXT WEEK
      • copier tech
        • 8193
        This model uses a chip, so it can also detect a new drum & reset the counter etc.
        Are you using genuine drums? I tried compatible & got this issue.
        Also what version SSW are you using?
        • tech28
          • Jun 2013
          • 434
          Know, I ran into that problem a few times in the IRC 2550's, 2880's 3480's, insert black drum, found that just by replacing the T/S belt, took care of message. there were several postings here in this site, from connections to firmware, ect. Replace T/S belt, even another one from a different machine, wierd, but it worked for me many times. Good Luck.
          • lilleputte
            • Jan 2013
            • 153
            Have seen this problem plenty of times.
            Replacement of this hvt use to solve "insert drum message"
            • techandtrader
              • Jun 2016
              • 335
              insert drum message on c3380 was a dirty problem with the ITb. Updated system software killed the false/incorrect error message.
              Have been using some aftermarket drums in the C5030 and C5035 without a problem. I am using OEM drums and replacing the drum cylinder only. I will not use them in the higher ones. The HVT doesnt like it and there are other problems it causes too.
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
              • petermays
                • Mar 2017
                • 91
                hi.
                if you look under the drum unit you will see a copper plate.
                it grounds drum unit.make sure its connecting to the drum unit.
