Cleaning Web not moving on iR8295
  • V-P
    • Apr 2011
    • 679
    [Misc] Cleaning Web not moving on iR8295
    This is an Adv 8925 series.
    The cleaning web is not advancing.
    I have checked the solenoid and it operates ok.
    I have even replaced FM3-7339 Fixing Drive Assy.
    If I remove the Fixing Drive than I can physically move by hand the wheel (in the photo attached) and the web advances as it should.
    But I don't see a physical connection between that wheel or an arm of it and the white plastic arm of the solenoid of the Fixing Drive.
    Am I missing some part or what ?
    Thnx,
  • copier tech
    • 8105
    Re: Cleaning Web not moving on iR8295
    Thnx,
    [ATTACH=CONFIG]41699[/ATTACH][ATTACH=CONFIG]41700[/ATTACH]
    The one way needle pin clutch can fail & the shaft it drives can wear down & slip so wont drive the web.
    Whats the main count on?
