IRC 5185
  • kirwayne
    • Sep 2008
    • 30
    IRC 5185
    IRC 5185 with an E748-4000 and E 748- 4894 changed out Main Controller cleaned the copper tips on the various other boards but still having the same issue. Can anyone point me in the right direction thanks
  • anothertech
    • 1771
    The next step would be to replace the open interface pcb.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Blank Display, Green LED Light is ON and the Machine Cycles : iR C5180 Series
      Approved
      Symptom
      1. You have a blank display, the green LED light is ON and the machine cycles when turned ON.
      2. The machine will not go in Download Mode (2&8) even if you change the bootrom chip to another one.
      Cause
      The Sub Main Boards can short out the Main Controller if defective. No response from the 2&8 (Download) command even when you replace the bootrom chip is another indication that the Main Controller is shorting out.
      Action
      1. First remove the SUB LAN-bar-A (LAN connection, HDD controller, HDD power supply) board from the Main Controller and see if the machine displays an E748. If so, replace the SUB LAN-bar-A part number FM2-6851-000.
      2. Remove each sub board until you get a response (error code, progress bar, etc...) on the display panel. The sub board removed is defective and needs replacement.
      3. Please note that any of the Sub Main Boards can cause the same effect. In this case, the Sub Lan-bar-A board was shorting out the Main Controller. Remove each sub board one at a time and turn machine ON until you receive some response from the display panel.
      • kirwayne
        • Sep 2008
        • 30
        Will give that a try cause I switched out every board and checked the memory same issue, however didn't try the Open Interface PCB.
        Thanks much
        • kirwayne
          • Sep 2008
          • 30
          Part Number
          Anyone happen to have the part number for the Open Interface PCB for the 5185?
          Thank you
          • BLITZKREAGG
            irc 5185
            FM2-7430-000
