IR ADV C5250 New Drom doesnt fit
  • CCC Repair
    • Sep 2014
    • 47
    2D22E085-1AF6-40F5-82AB-D2E91DF46DD5.jpg BBA5B52E-4E05-41CE-9506-31169D60A317.jpg 5B4AE549-FD98-4FEC-A2BC-B7FCAE3DEF5B.jpg
  • copier tech
    • 8174
    Re: IR ADV C5250 New Drom doesnt fit
    The black drum is different to the colour, which drum are you replacing?
    You can simply 'snip off' the rear plastic stopper to make it fit.
    • CCC Repair
      • Sep 2014
      • 47
      • bobburnsreb
        • Mar 2015
        • 233
        clip the two tabs off the rear of the unit and it will drop right in
        • copier tech
          • 8174
          Black drum is differant to the colour, looking at your picture it clearly shows BLACK!
          • CCC Repair
            • Sep 2014
            • 47
            • copier tech
              • 8174
              The black drums are cheaper than colour so most companies only stock the black & modify them as you did.
              • CCC Repair
                • Sep 2014
                • 47
