After Firmware Update the Job Status/Monitor is Missing on C5045
  • techandtrader
    • Jun 2016
    • 327
    #16
    Re: After Firmware Update the Job Status/Monitor is Missing on C5045
    Maybe a good time to upgrade to the 5200 series instead. You can use the fuser and all the consumables from your c5045. MMI clear in the past would wipe just user settings and esp. network settings. I have never heard of trial meap apps. For the price a Scan and Print at the same time function can be accomplished with a DR-c240 instead for a lot less money.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • kevinds
      • Feb 2019
      • 10
      #17
      Originally posted by techandtrader
      Maybe a good time to upgrade to the 5200 series instead. You can use the fuser and all the consumables from your c5045. MMI used to just take out the network settings and user settings and not Licenses.
      Not sure, I didn't have network access back at that point.. I did the Initialize all Settings that you suggested, that definitely took out the licenses if the MMI didn't.
      • nicknt82
        • Nov 2011
        • 155
        #18
        Originally posted by kevinds
        Howdy,
        I updated the firmware on my/our C5045 printer, trying to get SMTP sending to work. After a few reboots and profanity shouted at the email provider, that is working..
        My issue since rebooting has been that the Status/Monitor function is missing from the on-device display.
        If I log in with the web-interface, I can see the status, but it is missing the Restart Job function that the on-device view offers.
        Pressing the Status button, I can see the Consumables tab information, but the actual 'Tabs' are missing for Copy/Print, Send, Receive, and Store.
        Yes, I have read the manual, searched the forum and the web. I read the manual again and again.
        I am sure it is a 'check-box' somewhere, but I can't find it.
        What did I do/change and how can I fix it?
        Thank you,
        Kevin
        Try this: SM level 2
        • kevinds
          • Feb 2019
          • 10
          #19
          [ATTACH=CONFIG]41950[/ATTACH]
          Close,
          It was actually set BML-DISP to 0
          Screwed up other things before figuring that out though... Oh well, live and learn I suppose
