Canon iR2545
  • purwoto
    • Sep 2017
    • 19
    [Misc] Canon iR2545
    Hello All
    I have a problem with Canon IR2545,
    when the engine is turn on from the main switch, the engine does not respond to anything, only the power light is on. the engine will run after pressing the ON button in the control panel. even then the machine cannot be ready, only displays the progress bar. how to solve problems like this?
  • yez
    Re: Canon iR2545
    have you clean RAM and ROM yet?
    • purwoto
      • Sep 2017
      • 19
      Re: Canon iR2545
      yes, I've done it, but didn't solve anything.
      • kuby
        • Oct 2007
        • 1396
        Re: Canon iR2545
        Did you try putting in another hard drive from a good machine?
        • purwoto
          • Sep 2017
          • 19
          Re: Canon iR2545
          not yet, because the machine is only one.
          • kuby
            • Oct 2007
            • 1396
            Re: Canon iR2545
            Do you have a hard drive and system software to reload?
            • purwoto
              • Sep 2017
              • 19
              Re: Canon iR2545
              What do you mean by hard drive? I have a laptop and cross cable to reload the system software, but I don't have the system software, do you want to share it with me?.
              • nicknt82
                • Nov 2011
                • 155
                Re: Canon iR2545
                Originally posted by purwoto
                Hello All
                Clean RAM or replace new RAM. If's not solve, replace new Maincontroller PCB
                • purwoto
                  • Sep 2017
                  • 19
                  Re: Canon iR2545
                  Can it be solved with reload the system software?
                  • kuby
                    • Oct 2007
                    • 1396
                    Re: Canon iR2545
                    I would try reloading firmware/software first.
                    • purwoto
                      • Sep 2017
                      • 19
                      Re: Canon iR2545
                      Yes, I will try it but where can I get the firmware.
                      • nicknt82
                        • Nov 2011
                        • 155
                        Re: Canon iR2545
                        As you said " the engine does not respond to anything, only the power light is on." So how can you reload F/W ?
                        If you can go on Service Mode, you can try reload F/W.
                        • purwoto
                          • Sep 2017
                          • 19
                          Re: Canon iR2545
                          ok thank you friend, so what steps should be taken?
                          • kuby
                            • Oct 2007
                            • 1396
                            Re: Canon iR2545
                            You hold down the 2&8 keys while turning the machine on and wait for it to go into download mode...
