i have a canon ir 1024f always displaying paper jam after making a copy both from tray and bypass have tried changing sensors the problem is the some as soon as the paper reaches the exit sensor the red right 'll show and the paper 'll come out the display paper jam what could be the problem
Paper jam
Re: Paper jam
i have a canon ir 1024f always displaying paper jam after making a copy both from tray and bypass have tried changing sensors the problem is the some as soon as the paper reaches the exit sensor the red right 'll show and the paper 'll come out the display paper jam what could be the problem -
​Comment
​Comment
Re: Paper jam
1. the movement of the paper towards the exit becomes difficult(If the lower roller is causing this, it wont show any code)
2. the exit sensor finding it difficult to return to home position after the paper passes (usually caused by slight displacement of the sensor flag in its position)
Conclusion:
Once the sensor allows the copy to exit, it means the exit sensor is working fine. If the exit sensor is not working, the copy would stop before it.
Suggestions:
1. Check for clogs or wear in bushings at each end of lower roller
2. Unset and examine the movement of the sensor flag to see if it is smooth
3. Replace the fuser unit with a working one to guide you to where the error is.
I hope you finally smile after the headache buddy!Comment
Re: Paper jam
If the jam happens after the paper exits, my suspicion is:
Conclusion:
Suggestions:
wllmcchrn
Re: Paper jam
Did you check the sensor flags going into and coming out of the fixing unit hanging up?
Is the image correctly centered each time?Comment
