canon c5035 splotches
  • Jerrygbs
    • Dec 2008
    • 193
    [CQ] canon c5035 splotches
    I have a c5035 putting black splotches on copies. This my happen in 1 out of 50 copies B&W or color. Parts replaced fuser, black developer, black drum, ITB, ITB cleaning unit.IMG954239.jpgIMG954240.jpgIMG954241.jpg
  • guitar9199
    • Sep 2016
    • 1100
    Re: canon c5035 splotches
    Originally posted by Jerrygbs
    I have a c5035 putting black splotches on copies. This my happen in 1 out of 50 copies B&W or color. Parts replaced fuser, black developer, black drum, ITB, ITB cleaning unit.[ATTACH=CONFIG]42587[/ATTACH][ATTACH=CONFIG]42588[/ATTACH][ATTACH=CONFIG]42589[/ATTACH]
    When you replaced the ITB, did you make sure you cleaned the rollers in the ITB Unit?? This ALMOST looks like the transfer belt slipping, maybe causing the cleaning blade to "chatter" on the belt.
    OEM Belt/Cleaning Blade or aftermarket?
    • Jerrygbs
      • Dec 2008
      • 193
      ITB came out of a running machine, original ITB in different machine had no problems, the image is registered fine on the copies and the problem is still 1 in 50 or so
      • moh964
        First check your power voltages.then check your primary charging of black drum
        • Jerrygbs
          • Dec 2008
          • 193
          my wall voltage is constant, I will check black primary charge in the morning Thanks
          • copier tech
            • 8176
            looking at your samples, classic fusing issue, but you say you have replaced the fuser.
            Are you using genuine toner?
            • Jerrygbs
              • Dec 2008
              • 193
              changed fuser several times using oem parts
              • copier tech
                • 8176
                And what toner are you using?
                • JPiek
                  • Oct 2014
                  • 435
                  I've seen similar on a C5035, printing on A3 Glossy paper.
                  Temp. of the fuser dropped while printing, so first copies came out perfect, then fixing temp started dropping until it was to to low to properly fuse the toner to the paper, next copies started giving smudges...
                  You can see the temp. dropping in Servicemode, i think it was in DISPLAY-ANALOG-FIX-* but not sure...
                  I've set the papertype to HEAVY and issue was solved..
                  Johan
                  • Jerrygbs
                    • Dec 2008
                    • 193
                    I have the fuser temp turned up and the cassette set to heavy paper even though its 20 lb paper. Its definitely a fuser problem but the temp isnt dropping that much and it only does it for one copy in a run
                    • niyaskarimba
                      • Sep 2014
                      • 110
                      Kindly share us,which toner are you using??
                      Once we use GPR 30 toner instead of C-EXV 28 OEM tone we had faced the same issue.
                      • zoraldinho
                        teacher-guide-expert-guru
                        • Mar 2008
                        • 5015
                        This toner will damage fixing rollers over time.
