IR 3300 Not Printing
  • princepriyu
    • Jul 2025
    when i start my machine IR3300 for the first time every day it does not print. it's happening since few days
    it prints a BLANK page i even tried photocopy / print from computer and even its configuration print from its report settings.
    all BLANK pages. in early morning or even when machine not used for 6-7 hours
    (PLEASE CHECK IMAGE ATTACHMENT)
    can someone track the problem
    to eliminate the problem i'v even tried changing
    PCR (Positive Charging Roller)
    DRUM
    but even though same problem persists
  • copier tech
    • 8142
    Re: IR 3300 Not Printing
    DRUM
    [ATTACH=CONFIG]42598[/ATTACH]
    [ATTACH=CONFIG]42599[/ATTACH]
    What is the main counter on?
    From your sample it looks like the dev unit is shorting to to the drum.
    Replace the dev unit.
    • princepriyu
      but it prints fine after some time may be after 10-12 blank pages ??
      is this possible even when problem is with dev unit
      • copier tech
        • 8142
        It can happen.
        When was the machine lasted serviced/cleaned? could be large amounts on toner inside the machine.
        WHAT IS THE MAIN COUNT ON?
