f display on the screen at gp200
  • pearlpdy
    • Jul 2008
    • 44
    i have gp200 machine, past 10 days i have suffer from one problem at machine, there was f display on the screen at machine no other function not worked, what's the problem, what can i do, plz help me
    • 23008
    Are you sure about that code?
    There are no "F" codes, but a whole lot of "E" codes. If so, I'll need the whole code: E---, including the three numerical characters to be able to help you. =^..^=
    • CanonHPTech
      • Apr 2007
      • 235
      Sounds like the machine is cursing at you. Just kidding. Gonna need more than a "F" as a desription. Thanks.
      The glass maybe half full, but less is more...
      Printer + Fax + Copier = Jack Of Many Trades,
      but Master Of None
      Color Copier = Not A Color Printer
      InkJet MFP = Not A Fax Machine
      B/W Copier = Not A Press
      Finisher = Deal Closer (salesman, not accessory)
      Copier Tech = Admin's Stress Ball (Scapegoat)
      • Peter Sim
        • Sep 2008
        • 445
        i also facing this 'F' problem.Off power and just disconnect the IP board connector J526 .The J526 cable is connect to download mode(below panel)
        • pearlpdy
          • Jul 2008
          • 44
          sir, i will try to disconnect the u said above mention IP board connector j526, but no usage same problem occured plz help me if any other way.
          • Peter Sim
            • Sep 2008
            • 445
            F sign
            Sorry,i have no idea.
            My problem:When "F" sign appear,the LCD touch screen all hang and cannot touch the display and also sometime will cause machine off and on few time.I just disconnect the J526 and off and on back the machine."f " sign disappear and machine back to normal untill now.
            • rosaro75
              • Mar 2009
              • 87
              it is ip board problem. it shows the all capacitor in ip is lost its life. you replace all capacitor. the board will work
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                A picture of the control panel may be of some help to us, so we all can see what it is that you are seeing!
                • rosaro75
                  • Mar 2009
                  • 87
                  hey it is nothingya. the F came in the place of $ where leftside top corner. if small 'f' comes copier will work normally. and for service mode in activated condition. you no need to press star button.
                  if capital 'F' comes control panel will hang. machine stop working
                  • pearlpdy
                    • Jul 2008
                    • 44
                    Yes sir, "F" display on the topleft corner, how can solve the control panel hang, and what can i do somebody told me remove the IP board and blow the hot air back side of board, but that is nonsense concept, but miracle machine came normal condition and work properly, but actual what problem and how can i solve it, sometime only it work proper and all the time not working, i need solution, plz help me
                    • rosaro75
                      • Mar 2009
                      • 87
                      i already told you to replace the capacitor. due to moisture the capacitor lost its value. when you blow hot air the capacitor become dry and work again. so before you get the problem again you replace the capacitor. ok
