Late Printing Canon IR3300
  • princepriyu
    i am using Canon IR 3300 photocopier machine
    every day after i start the power button, my machine does not print any page
    photocopy, print given from computer or even any document saved in its mailbox
    but it starts printing without any problem after some time
    nearly after 45-50 minutes
    suddenly, some times when i give multiple prints it prints page half then remaining all copies blank after that,
    i have to wait for some time to start the prints again
    for eg:- if i give 12 pages print, then it might print 4 pages correctly and 5th page half and remaining 6 to 12 pages blank
    what may be the problem
    what should i check
    thanks for the support
  • kuby
    • Oct 2007
    • 1410
    Re: Late Printing Canon IR3300
    Hard drive could be going out. Replace and reload system software.
    • princepriyu
      what should i check
      Finally problem solved after for a very long checkups with other same machine
      i had replaced nearly every thing with other two same machines
      i replaced Drum unit, developer unit, HDD with other unit
      but all were acting same
      all works perfect on the other machines
      finally when i replaced the power supply it started printing
      and when i tried my power supply (Defective) on other machine
      that machine started delivering BLANK COPIES
      so i concluded on FAULTY POWER SUPPLY
      Friends thanks for the support,
      if any one faces a such problem
      may use this to try solving their problem
        • 8195
        Wow this is an old machine!
        Sounds like the HDD is failing
        • princepriyu
          Hard Drive if Fine
          Solid State Drive
          SSD
          the problem was with
          Power Unit
          i replaced it
          now the OLD machine is working fine
          anyway thanks for the post
