Canon IR 3230 No display
  • suresh968
    • Apr 2015
    • 14
    [Dead] Canon IR 3230 No display
    Hi ,
    After switching power my Canon IR 3230 No display. Its looks like dead
    Re: Canon IR 3230 No display
    Originally posted by suresh968
    Hi ,
    any lights?
    do you hear fans/motors turning?
    you ask for help but provide no info for us to help you with
    • suresh968
      • Apr 2015
      • 14
      any lights?
      Green Light is On but fans/Motors are not running
      • copyman
        Owner / Technician
        • Sep 2005
        • 4721
        Do you mean after "switching power on" or "switching" power supply board?
        It's been awhile but think no display has somewthing to do with the HDD or system software. Also think bad or missing ROM would cause this.
        POSTERS PLEASE PROVIDE MORE DETAIL IF YOU WANT HELP !!!!
        • Deepaklohmi
          • Aug 2023
          • 6
          i have same problam with ir3230 after RTC jp1 reset machine gets start but after 1 minut everythings goes off
          pls help what to do now Green light is still on
          Recovery procedure done Turn off the main power switch and short out across the 2 contacts [A] of JP1 on the main controller PCB for
          approx. 1 second using a conductor wire or other.
          (This will reset the register value to the default.)
          pls help
          • Buenor
            • Dec 2021
            • 21
            For me it looks like LVPS or HVPS issue.
            Try minimal configuration or with opened all doors (this will cut off all bigger electrical circuits). Better is to remove fuser, ITB, drums, devs.
            This way you eliminate any short circuit in consumables or grounding problem.
            • Deepaklohmi
              • Aug 2023
              • 6
              Nothing happens with minimum circuits connected no fuser no drawer no develper unit no adf connected
              • Buenor
                • Dec 2021
                • 21
                So next step I will do is measuring a voltage on connectors. If you have a service manual you can check a correct values. Lastly, do you have any other working machine? It is possible to exchange a boards and power supplies between them. It is good practice to put suspended logic boards like main controller, drum drive into. into working machine. Opposite with a power supplies - working PS to the suspended machine.
                First, Very important, do not exchange main controller with additional boards on it, like serial and counters board. Them must stay in original chassis. Second, do not exchange more than one board at same time! Change one and check the machine.
                If you need and want, I will search a voltage values and connectors to check for you, but tomorrow
                • Deepaklohmi
                  • Aug 2023
                  • 6
                  Thanks a lot
                  • Buenor
                    • Dec 2021
                    • 21
                    Checklist:
                    1. Is 12 V output from theMain Controller PCBJ3?
                    2. Is 12 V supplied to theMain Controller PCBJ22?
                    3. Is 12 V output from theLowVoltage Power SupplyPCB J812?
                    4. IS AC supplied tothe AC Driver PCB J6010?
                    • Deepaklohmi
                      • Aug 2023
                      • 6
                      Checklist:
                      main controller bord has only 3.5v supply in
                      no 12v in controller board
                      • Buenor
                        • Dec 2021
                        • 21
                        sorry my mistake, I saw wrong manual I try to obtain a correct one or Deepaklohmi maybe you have and could check?
                        • Buenor
                          • Dec 2021
                          • 21
                          sorry, manual for this machine is not reachable for me... that's why I mistaken with another one with similar number ;/
