Canon 1435if
  • Printer77
    • Sep 2019
    • 57
    [Jamming] Canon 1435if
    Hello! i have problems with my Copier machine, on every pick up paper jams in the middle of fuser, i changed whole fuser and Paper Feed Roller Shaft( Because it was broken), the imaging drum seems fine.... did someone have similiar problem?
  • DeanCraythorne
    • Aug 2019
    • 2
    Re: Canon 1435if
    You could check the exit flag, or check the actuator arm on the drum unit - these can get bent if installed incorrectly. Good luck. If these are all ok, have you checked the state of the feed rollers?
    • Printer77
      • Sep 2019
      • 57
      Re: Canon 1435if
      Thanks!, well it is working at the moment, so i will let him to work some time and see, btw thank you
