IR 2830 paper jam between drum and fuser
  • gideon
    • 283
    copier is jamming every 3 copies or so, letter or letter-R the same jams.
    When the right door open the paper is folded "on the drum", the paper wasn't fed into the fuser rollers.
    Image on the paper is 2" - 52mm from leading edge to the point of stop on the drum (toner line).
    The leading edge registration is correct. The fuser rollers looks ok and turning freely.
    I replaced the regist. clutch.
    It can be the fuser motor or?????
    If you experience this kind of jam on 4570 3570 2230 2270 etc please advise.
  • Brian8506
    • 1667
    Re: IR 2830 paper jam between drum and fuser
    Jam code would help. I always remove all the black damper pads by each gate and sensor flag as they can cause issues
    • gideon
      • 283
      When I tried to find the jam history (as described in the manual) Copier-Function-Misc-P there is no Hist-prt, any idea where the jam history is hiding on this model?
      • Brian8506
        • 1667
        Display/jam
        • gideon
          • 283
          The error code is 0107, from the manual I see that it is ps13 (fixing delivery sensor), the paper doesn't get to the sensor at all, it stops before the fuser rollers.
          I suspect the fuser motor doesn't turn in time, it doesn't jam all the time.
          My question is it the fuser motor or?
          I talked to Hytec, they confirm my suspicion of failed motor, what I don't understand why it doesn't give me an error, only a jam.
          • Brian8506
            • 1667
            • Brian8506
              • 1667
              Mine only jams on LTR. Ltrr and legal are fine
              • gideon
                • 283
                Thanks you all for your input.
                As I mention above after talking to Hytec it probably the M3 (fixing motor FK2-0367).
                I also found this - look at dan7777 comment: IR 2870 wave ype printing
                • Brian8506
                  • 1667
                  Grounding plate is fine. I always check that. I'm going to try a door next week. No hurry. Machines works fine in LTRR
                  • petermays
                    • Mar 2017
                    • 91
                    hi guys.
                    can i ask..have yo checked you lower door..maybe the pressure isnt right and paper feeds funny.
                    if the pressure isnt right you will have paper feed issues and paper will fold and sometime be caught in the 2nd transfer unit.
                    • Brian8506
                      • 1667
                      I haven't but that is one thing I was going to try when I go next week. Thanks
                      • Herrmann
                        • Jan 2006
                        • 792
                        Mine is folding at the registration flag
                        There is a damper Pad at the end of the sensor flag, that becomes sticky. You can check this: apply some pressure at the sensor flag downwards, then try to move it upwards. If you feel a resistance before the flag comes free, this is your problem. Remove the damper pad and you are fine
                        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                        • Brian8506
                          • 1667
