Canon ir adv c5255i firmware
  • zuckryyu
    • Jul 2019
    • 31
    [CQ] Canon ir adv c5255i firmware
    Does anyone know,how to update firmware?
    Because my printer is printing very slow
    Sent from my TA-1021 using Tapatalk
    Re: Canon ir adv c5255i firmware
    Because my printer is printing very slow Sent from my TA-1021 using Tapatalk
    firmware more than likely will not fix it..
    HOW are you printing to it?
    WHAT are you printing to it?
    WHAT paper are you printing onto?
    those are just a start of my Q's.
    PhilB "The Dentist"
    • copier tech
      • 8144
      If the machine is on a network with net access simply enter service mode & select update SSW.
      • alex@wocltd.com
        • 430
        50xx/52xx when starting to print/run slowly normally means fuser is at end(or near) of life or on a few occasions hdd starting to fail(with no errors)
        • zuckryyu
          • Jul 2019
          • 31
          Hi, because, below the screen keep showing
          'starting up' i need to wait for at least 5 minutes,before it's getting on standby and ready to print....but when copying,it is on normal speed
          Only when printing it is slowing.
          • alex@wocltd.com
            • 430
            so what driver are using? would suugest you use ufr11 and see if any improvements?
            • wcanonw
              • Aug 2014
              • 404
              hello what type of driver are you using?
              PS takes time to process the impression.
              PCL or UFR II processes printing faster..
              • zuckryyu
                • Jul 2019
                • 31
                Im using pcl...but the main thing is that,it is not show 'starting up' at the pc,but at the printer screen,i dont think the driver is the problem.even when i try print configuration report also slow,need to wait about 5 mins,before it come out printed
                • guitar9199
                  • Sep 2016
                  • 1100
                  If the machine is telling you "Please Wait", the print drivers would have nothing to do with your problem.
                  How many prints are on that machine? If the total is anywhere near 300K, then you're likely looking at the fuser unit being close to end of life as was suggested above.
                  If you're well BELOW that number, you could also be looking at a hard drive that's getting ready to fail. A firmware update MIGHT help, but if you're just an end user, you might be better off hiring a Canon technician to come and service that machine for you. If you're a tech, get ready to order some parts.
