IRA4225 Error code E000014-002 displayed
  • ldfrepairs
    • Oct 2012
    • 148
    I have replaced the fuser film and presssure roller and error occurs occasionally. I have tested fuser motor and it works properly. Any advice and next step.
    drugstore-onlinecatalog.com
    Re: IRA4225 Error code E000014-002 displayed
    did you replace thermistor/stats?
    did you replace any bushings/bearings?
    did you buy parts a reputable source?
    did you follow the service manual on rebuild?
    did you reset any code/part life after rebuild?
    you really don't give any help to us with such a brief explanation of the repair.
    PhilB. "The Dentist"
    • ldfrepairs
      • Oct 2012
      • 148
      No I did not replace any thermistor
      yes replaced bushings
      yes, items were purchased from reputable source. purchased same items from source before
      yes follow step by step rebuild procedure
      I reset code, but did not reset count.
        • 37362
        You post would be seen by a lot more qualified Canon tech if you placed in the actual Canon forum. https://www.copytechnet.com/forums/canon/
