IRA4225 Error code E000014-002 displayed
  • ldfrepairs
    • Oct 2012
    • 148
    I have replaced the fuser film, presssure roller and bearings and error occurs occasionally. I have tested fuser motor and it works properly. Any advice and next step.
    drugstore-onlinecatalog.com
  • teckat
    • 16083
    Re: IRA4225 Error code E000014-002 displayed
    COPIER>FUNCTION>FIXING
    NIP-CHK Check of fixing nip width.
    Use case - When replacing the fixing-related parts (fixing Roller, Pressure Roller)
    - When a fixing failure occurs
    Adj/set/operate method
    1) Print approx. 20 sheets of A4 size paper.
    2) Make a solid black print (setting value: 7) with COPIER> TEST>PG> TYPE.
    3) Set the output of step 2 on the Multi-purpose Tray while placing the printed side down.4) Perform the size setting of the Multipurpose
    Tray.
    5) Select the item, and then press OK key.A sheet is stopped once in a state held by the Fixing Nip area, and is delivered
    approx. 20 seconds later.
    6) Measure the nip width of delivered sheet.
    It is judged as normal: (iR-ADV 4251: 8.1 to 10.1 mm, iR-ADV 4245/4235/4225 :7.5 to 9.5 mm) at the center, and difference
    between front and rear is within 1.0 mm. If there is an error, execute step 6.
    7) Check the Fixing Roller, Pressure Roller, and Fixing Lower Unit,
    and replace damaged part.
    Related service mode COPIER> TEST> PG> TYPE
    did u have a CQ issue before code
    >try this --remove drum n' dev unit and inspect the HV connections > now re-seat drum and dev unit.
    1. Check connection of the Connector (J2001/J203).
    2. Replace the Fixing Motor (M2).
    3. Replace the DC Controller PCB (UN2).
    how stable is your Supply Voltage from outlet
    especially Neutral to Ground - should be 0v +/- 0.5v at all times
    • ldfrepairs
      • Oct 2012
      • 148
      Thanks will perform nip width test
      • ldfrepairs
        • Oct 2012
        • 148
        I eventually got to replace the complete fixing assembly. check nip width but still getting the Error code 000014 displayed. Any other suggestion would be greatly appreciated.
        • teckat
          • 16083
          clear code ?
          Fixing Drive Unit ??
          Inspect the HV connections
          any other errors ?
          point to note
          Part number FM4-7897-000 goes to the higher speed models, imageRUNNER ADVANCE 4051/4251, and the color of the film is an off white color. Check the image below.
          Part number FM4-7900-000 goes to the lower speed models, imageRUNNER ADVANCE 4025/4035/4045/4225/4235/4245, and the color of the film is black in color. Check the image below.
          • ldfrepairs
            • Oct 2012
            • 148
            The Unit I replaced is the FM4-7900.
            Next step i guess will be to check the HV connections again and then replace the Fixing drive unit.
              Tekcat asked if you CLEARED the error!?
              • ldfrepairs
                • Oct 2012
                • 148
                Yes I did
                • giogi
                  Engineer senior
                  • Jan 2016
                  • 181
                  Check or replace the FM4-9179-000 MAIN DRIVE ASSEMBLY
                  "Knowledge is a source, but unfortunately ignorance is a sea."
                  • ldfrepairs
                    • Oct 2012
                    • 148
                    The main drive assembly is what I am looking at now. have requested a quotation to purchase
