Yep, that what it sez. The door is closed tight and the front is closed tight.
The customer reports that it started about a week ago and they had to use tape on the door to the front door.
Now that doesn't work.
I checked the I/O in svc mode. PO 4 bit 3 I think it was. It showed a 1 meaning the door open. I can manually push
that white button in the lower left area in with a small screw driver and it will show closed. I tried to put a piece of rubber on top
of the switch to help actuate the 2 micro switches I found behind the front door.
I'm missing something here. I am aware of 3 photo sensors in that system and blocked them.
Any suggestions?
Has anyone replaced these switches because they were actually bad?
I'll have a look through the manual tonight.
DR
Any suggestions?
DR
