IRC3380i Close right side door message won't clear
  • Desert Rat
    • May 2008
    • 1089
    Yep, that what it sez. The door is closed tight and the front is closed tight.
    The customer reports that it started about a week ago and they had to use tape on the door to the front door.
    Now that doesn't work.
    I checked the I/O in svc mode. PO 4 bit 3 I think it was. It showed a 1 meaning the door open. I can manually push
    that white button in the lower left area in with a small screw driver and it will show closed. I tried to put a piece of rubber on top
    of the switch to help actuate the 2 micro switches I found behind the front door.
    I'm missing something here. I am aware of 3 photo sensors in that system and blocked them.
    Any suggestions?
    Has anyone replaced these switches because they were actually bad?
    I'll have a look through the manual tonight.
    DR
  • Duffer
    Re: IRC3380i Close right side door message won't clear
    Are any of the tabs broken or bent? These would be on the "door"side.
      • 8132
      Any suggestions?
      DR
      I remember seeing this a lot when I worked on these old boxes.
      You are correct is is to do with then switch ass'y over time the front door becomes warped & doesn't make good contact with both micro switches.
      I used to resolve this issue by putting thick tape on the white actuator part of the switch to put more pressure on the switches.
      That unit has been modified see attached pdf.
      Close front door IR C2380 Series.pdf
      • Desert Rat
        • May 2008
        • 1089
        Duffer, Thank you for your suggestion. It does not appear that any of the tabs are broken or bent. But I did
        find a piece of plastic like a tab but it had a hook latch on it. I have not been able to locate where it came
        from yet. May be today I will find it.
        copier tech, Thank you for your reply and tech letter. I think that explains it all pretty well. I have saved it in to the folder
        and will apply the info today. But I had almost all of that stuff out yesterday. I was pretty close, good thing it wasn't a snake.
        It might have bitten me.
        Thanks again both
        DR
        • Desert Rat
          • May 2008
          • 1089
          copier tech,
          Thanks again for that letter. It helped a lot. I was able to remove the recommended pieces, but after that the aux pressure lever is useless.
          I might as well have taken the whole thing out. I still had to shim the switch actuator with some self adhesive material about 2-3mms. But at least
          it is working again.
          As an indy I am not on the mailing list for tech letters and really appreciate getting them when offered.
          Have good times
          DR
            • 8132
            copier tech,
            Have good times
            DR
            No worries these are still a good box for the age.
            If you still have issues sometimes simply removing & refitting the right hand door helps the screws work loose over time.
            • Desert Rat
              • May 2008
              • 1089
              I ended up taking the door off at one point anyway, the lower hinge pin popped out of the nylon thing ma jig.
              I have couple more of those models out there too. I see that they are getting aged and I will try and replace them
              as soon as I can.
              DR
