AdvC5045 misalignment
  • repeatcopiers
    • Sep 2008
    • 591
    I have a C5045 that if you copy using the ADF copy looks perfect, but if you place the original on the platen glass, it is cutting off the top 1/2 inch of the page. Any ideas? I've seen this in reverse where the ADF was the issue but not the glass.
  • FrohnB
    • Jul 2017
    • 1919
    Re: AdvC5045 misalignment
    Same orientation on glass as it is in drawer?
    Auto Rotate turned on?
    Enlarge/ Reduce settings selected?
    Sizes won't be detected correctly if you don't lift the ADF up high enough to get sensor to detach.
    Omertà
    • repeatcopiers
      • Sep 2008
      • 591
      Just figured it out, had to go into service mode, Adj IMG Y to get back centered.
